Well I've managed to put a little over 8k miles on the used 2010 NT I bought last September.
And it's gonna need new tires.
Since the NT requires removal of exhaust and rear fender to change it's rear tire without a worktable.
Ever since buying the NT I had been planning on buying a Harbor Freight motorcycle lift:
http://www.harborfreight.com/1000-lb-capacity-motorcycle-lift-69904.html
But I've concluded that I just don't have the room for the Harbor Freight lift.
Plus moving a 300lb lift around on the plywood floor of my "garage" does not sound like fun.
SO
I stole an idea from post #9 in this thread:
http://www.hdforums.com/forum/touring-models/288073-home-made-lift-table-pics.html
And I spent a few hours last Saturday making basically the same thing:
Mines a fair bit smaller than that Harley rider's table.
Mine is only 22" wide x 11" high x 8' long. And each section is 32" long.
I used 2x10's for the sides and and 2x6's for the deck.
I had planned on using 2x8's for the top deck. But the local Home Depot did not have any 8-ft 2x8's in stock.
Hopefully 11" deck height plus the 15" of fender height provides enough room to remove rear tire.
I believe it should. Because rear tire is about 23" tall. (17" rim + 2x 3" tire height = 23").
As you can see. It's rather crude looking. I only had a circular saw to cut the wood. So some cuts are not the straightest.
Currently all the 2x10 making up the sides; are simply attached to each other at right angles via deck screws. And then the deck is screwed on top of the sides.
It feels rather sturdy. But if I feel it ever needs some strengthening; I may add some vertical 2x4's sections in side each corner.
But as it stands right now. I just need to add a couple screw holes to secure the ramp to table, tie-down anchors, and something to prevent the sections from sliding apart when loading a bike into the Sport Chock.
After work today I bought some eye bolts and D-rings to use for tie-down anchor points. I plan to add some 2x4 cross members under the deck and attached to the sides.
I'll then mount the eye bolts and D-rings though both the 2x6 deck and the 2x4 cross members.
The wood cost about $65, box of deck screws $9, and the eye bolts/ D-rings another $10.
I'll try to remember to take some photos while changing tires next weekend.
And let everyone know how it performed.
--ET
SO
--ET
