Results 1 to 3 of 3
Thread: Long miles between valve adjustment
  1. #1
    banjoboy's Avatar
    Join Date
    Dec 2010
    Port Townsend, Washington
    Posts
    1,200
    My Gallery
    I picked up my bike this morning from the shop. I'm at 49,560 miles, closing in on the coveted 50K sticker. I asked the mechanic to change all fluids, tighten everything up and check/set the valves. The last time I had the valves set was at 30k. All valves were in spec after 20K miles, no adjustment made. I asked him how this could be and he replied, "Because it's a Honda." I'll have the valves checked again at 70k.
    Terry
    › Site Search for: Long miles between valve adjustment
  2. #2
    Site Supporter Woodaddict's Avatar
    Join Date
    Jan 2012
    Salisbury,NC
    Posts
    682
    2017 Miles:
    016200
    My Gallery
    Re: Long miles between valve adjustment
    No problem I snuck up on valve checks, 8K, 20K, 35K, next will be about 40 , now at 168K miles
    Previous:'
    97 PC800 67,664 miles in 3.3 yrs::'96 PC800 160,560 miles in 10.5 yrs::'82 GL500 Silverwing::'83 Shadow500::'78Suzuki GS550::'73Suzuki TC125::Suzuki TM400
  3. #3
    Site Supporter DirtFlier's Avatar
    Join Date
    Dec 2010
    Posts
    1,485
    My Gallery
    It's normal for the greatest wear to occur during the first 10k-20k miles then the valve clearances settle-in.
    Whenever I've checked it, I've found one of two exhaust valves barely on the loose side of the tolerance but all the intakes were OK. Being loose is much better than being tight!
+ New Posts
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
