Help with headlight protector
Montana
2011 Black NT700
When I removed the protector for cleaning only one of the attachments stayed stuck to the headlight. Any ideas of what type of glue or adhesive I could use to reattach them?
Thanks in advance, Clint
My local ACE Hardware sells those Velcro "dots". I'd just replace them instead of using an adhesive that might be more permanent than you want...
Northern Virginia
You are looking for 3m dual lock disks (or dots). I think Laminar Lip will sell you a small number of spares for a modest cost if you can't find any locally.
ACT, Australia
Black 2006 NT700V
Hi Clint,
You need some of these: Dual Lock? Individual Loose Coins
And you also need to make sure the headlight is absolutely and spotlessly clean before you stick them on (use Isopropyl alcohol to wipe the area where the dots will go after you've cleaned it).
