Total newby to my 2008 700. Doing a rear tyre change and one thing leads to another. Wound up pulling out the final drive to check all the splines and drain the drive ( whilst it was out ). Upon washing out the input spline all the degreaser disappeared, only to appear in the housing. Hey presto two holes at the base beside the nut. This was the most moist joint in the drive. Am I right in guessing they are breather holes to keep the input shaft spline well lubed as they are well above the oil level when the bike is level and this spline is the only one with an oil seal. Any one else's knowledge on this part would be much appreciated.
