OK just had a major service (new PR4 front, spark plugs, liquids, tappets etc. etc. - the EXPENSIVE one) and something doesn't feel quite right. SO before I take it back I could do with some suggestions as what it may be.
Symptoms:
My thoughts are:
I've just checked the front tyre pressure and it's 222kpa - 32.19psi (supposed to be 250kPa - 36psi) so it's possible that it's the tyre pressure - will know tomorrow after a run at the right pressure.
Winter fuel blend
In the US there is a change of the blend of petrol between winter and summer - I haven't found any mention of this in Europe but we do get a similar result with mileage so it probably happens here as well.
The winter/summer fuel blends are due to RVP (Reid Vapor Pressure). In winter the RVP is higher (in the US* about 9 psi) to help the car start and run more easily. In summer it is, therefore, lower (in the US about 7.8 psi) to stop the petrol evaporating in the tank.
Using summer blend in winter could cause the engine to run a little rough as it doesn't vapourise as easily. So it could be this though, the temperature is still in high teens (16? C today - 22? C yesterday), therefore unlikely.
I would welcome any thoughts on the matter especially if you have had similar symptoms on your NT.
Symptoms:
- Below 3500 rpm the bike is silky smooth
- Between 3500 and 4000 rpm there's a hint of vibration.
- Above 4000 rpm there's a definite vibration that wasn't there before so she's definitely "buzzy" at 70 mph.
- When accelerating relatively hard there can be a hint of hesitation before she picks-up like I'm a quarter of a gear too high.
- The "feeling" I'm getting through the bars when cruising is like I'm in 4?th not 5th gear - so a very different response to accelerating.
My thoughts are:
- A dodgy spark plug
- A Plug cap not fitted properly (I had them changed under the "recall" 4 years ago)
- Tappets not set perfectly (though she doesn't sound tappety)
- Have they put a winter fuel blend in the petrol?
Winter fuel blend
