Well, I thought I had been fighting a bad fuel situation for a couple of tanks now but things turned worse tonight on my way home from a short ride after work. I have been dealing with a hesitation issue at about 3500 rpms and cruise at 5000 rpms also would not want to start after sitting about 3 to 4 days without twisting the throttle and holding it open till it started (replaced CKP had code 1-9 last fall and ran great). This issue has been intermittent on and off for about 3-4 weeks. Tonight on the way home after about a 40 mile ride it started doing the hesitation thing again at upper rpm's also in in all lower rpms and at idle, it stopped running as I coasted into the driveway with the clutch pulled and MIL flashed code 1-3 fuel injector #2 issue. The manual say check connector do some testing of injector then replace if found bad. I've been trolling some of the older postings and no one has ever replaced an injector, Charlieb had a connector come loose and many sparkplug cap issues(mine is 2011 model). Has anyone one else had any issues or dealings with code 1-3 ? Any help would be great. Thanks in advance (still would like to make the Cashmere run and meet everyone)
Kevin
Kevin
