I may have an electrical problem concerning the alternator and the Regulator/Rectifier. So, I'm looking for advice and/or reassurance.
Note: I have a SkyRich LiFePO4 battery on the bike which has it's own intelligent control system built in.
Problem:
The 3 core cable (3 yellow sheaths) which runs from the alternator (I think) to the Regulator/Rectifier is hot to the touch. You can hold it but it is hot enough to be very concerning. It takes about 30 seconds from start up before you feel the heat and after about 90 seconds it seems to reach maximum heat (hot enough to be concerning). I'll try to get an actual temperature reading later. The cable between the alternator and the 3 pin connector is slightly hotter than the cable from the 3 pin connector to the Regulator/Rectifier. The Regulator/Rectifier heat sink is cold to the touch. I have not checked the temperature of this cable ever before.
So far I have left the bike running for more than 3 or 4 minutes so can't say if it gets hotter or cools down later. I will take her for a run tomorrow (Monday 26th) to see if the cable stays warm or cools down after a while.
I have checked the connector and it is clean without obvious signs of corrosion or heat damage. I cleaned it with some electrical cleaner anyway and put a touch of electrolytic grease on the pins. This hasn't made any noticeable difference at all - the cable is still as hot!
Request:
Does anyone with knowledge of the charging system on the NT700 know about this problem? If you also have experience of LifePO4 batteries with built in charge controllers, that would also be helpful.
My thoughts are that the Lithium battery, with it's intelligent charge controller, is drawing maximum power after starting the bike which is causing the cables to run hot as there are no signs of heat damage to the cables or the connector. This is just conjecture on my part.
Problem:
Request:
