CREEPUR
I am adding fog/driving lights and want them to go off when I switch the High Beam on (due to PA regulations). I already isolated the high beam wire and low beam wire and I have 2 relays 5-pin and a 4 pin.
Am I on the right track here.
The 4 pin relay - used to keep lights on with low beam
Terminal 30/51 connects to battery
Terminal 85 connects to ground
Terminal 86 low beam wire as the trigger
Terminal 87 output to Terminal 30/51 on the 5 pin relay
The 5 pin relay - used to shut lights off when highbeam is turned on
Terminal 30/51 connects to terminal 87 on 4 pin relay
Terminal 86 is the high beam trigger wire
Terminal 87A connects to the Fog/driving lights - power is removed when highbeam triggers
Does this make sense or am I making it too complicated.
