Does the NT have the standard ATC/ATM fuses?
That is how mine was as well... ATC for OEM and ATM in my Fuzebox...I believe the OEM fuses are the larger ATC fuses. My accessory fuse block uses the smaller ATM fuses.
Yeah, I read that.....dont know why anyone would want an open one.Chris, the ATC fuse ATC fuse has a fuse element that is closed or sealed inside the plastic housing and the ATO fuse has a fuse element that is open or exposed on the bottom of the fuse between the blades.
I guess you probably knew that, but I'm like you, I don't know why one is open and the other's closed.
Warren, RedLdr1, Mike is correct. I changed out my main battery today and low and behold, one of the fuse compartments was right over the battery, and it was full of ATM fuses. ATMs are 11 mm long, ATCs are 19mm. Maybe there is more than one fuse block?That is how mine was as well... ATC for OEM and ATM in my Fuzebox...
