NL7U
Redbird...
From your username and description of how you extended your brake line, I assume you have a non-ABS model NT700, which has a completely different type of fitting on the lower end (see Honda part number 45124-MEW-851). However, if I read your reply correctly, it seems you have found that you can add extra banjo fittings to each end of your existing hose. Is that like a banjo to banjo connection? I sure would like to get an education in brake line fittings and what will fit what. If I am having problems finding ABS stuff, then others also are having problems and maybe we could pool our brains and come up with the answers that we need to safely raise our handlebars.
