Oil filter length.
Bluerider3
Received a friendly warning to make sure to not buy an oil filter longer than the stock NT700V oil filter. Reason being that when you roll off the center stand and it folds up, it can punch a hole in the longer filter. My question is how long/tall is the stock oil filter for this bike?
Richardson, TX
There should be a thread here with dimensions but if you google the dimensions of an M1-108 by Mobil1, those dimensions work
Fram equivalent also fits
OEM 15410-MFJ-D01 64 mm or 2.5". Some of the aftermatket ones that look like they would work are 2.75" and they will puncture.
Moses Lake, WA
2010 Silver NT700V
The oil filter for the NT700V is not any smaller than any other Honda filter. In fact Honda uses the same filter on all their motorcycles. The issue with the NT is clearance.
You can use a WIX WL10000. It was specifically designed for Honda motorcycles.
Tonydtiger1971
Wouldn't this one puncture? Be careful of the FRAM you buy. one is 1/4" longer and it will puncture.
Rock Hill SC
2010 silver NT700v
Fram PH6017a which is used on a ton of Hondas and others...xrefs to HONDA '15410-MFJ-D01'...but the 'Fram PH6017a' specs are
Gasket I.D. 2.21"
Gasket O.D. 2.48"
Gasket Thickness .21"
Gasket Usage Base
Product Height 2.87" --- TOO LONG
Tonydtiger1971
Gasket I.D. 2.21"
Gasket O.D. 2.48"
Gasket Usage Base
Yep, that one.
