I have a set of MCL risers with the MCL handlebar clamp (RAM ball and Powerlet). I'd like to try the Rox Speed FX 2in. Pivoting Riser instead of the MCL riser and still use the MCL handlebar clamp. That would require the ROX riser to have a 1 1/4" bolt pattern (stock size) clamp. I have a set of the ROX Block risers on my VSTROM and the bolt hole dimension on those is 1 1/2", since it is adaptable to 7/8" or 1 1/8". I've seen posts from several folks with that riser and am hoping someone with that set might measure the bolt hole dimension and post... Fingers crossed it is 1 1/4.. I picked up my Transalp clutch cablet oday and my neck is ready for some better ergos..
