Well, I needed a new GPS because the old Garmin Nuvi kept failing due to the loose mini USB connector, so I purchased a new Garmin Zumo (660lm). So far so good, but then I needed to power it and read all the various postings, and decided that the best spot would be dead center near the handlebars, and since I was getting pains in my shoulders, I thought heck, I might as well get the Motorcycle Larry risers and the MCL cap with the mount for the RAM ball. Okay, but then the postings explained that I would need a longer clutch cable. No problem. And while I was at it, the prior owner had put on some grips which were loose. Heck, I might as well replace them with some new Honda grips. But at the cost of having the dealer order them, I said might as well spend a bit more and replace them with the Honda heated grips so I can extend my riding season. Okay, but that meant that I needed to power them too, so I just order the auxiliary power harness from Honda. Another package from an online dealer, the mailman thinks things are getting out of hand. All is good but you still don't have power for charging the iPhone? Answer, just order a Powerlet outlet and cable to run back to the battery and install it at the same time in the left hand change pocket.
I think I am finally done! The pannier locks are installed, the Bestin pannier liners are here, so if he is reading this posting, there is no need for Santa to come now.
Am I missing anything else?
