Motopilot
I ordered and am trying to install a SMIDSY turn signal reminder which "clicks" with the blinking light and after 20 clicks, beeps a louder tone to remind you to turn off the signal. Applying the brake resets the counter so it doesn't start counting until you release the brakes and start moving.
There are 4 wires to connect: one to ground, one to the brake light, and one for each of the turn signal lights.
I connected one wire to ground, and another to the right signal, and then turned on the ignition. I immediately hear a fast blip-blip-blip-blip (about 4x a second) and then it starts the louder tone after 20 blips. This is WITHOUT the turn signal on. If I turn on the signal, it then blips slowly in time with the turn signal light as it is designed to do.
It seems that there is a pulsing voltage on the line to "test" the bulb all the time when the light isn't flashing. When I connected a voltmeter to the line it reads about 3v, jumping around. (I don't have a scope to see exactly what's going on)
Does anyone know if this is how the turn signal lines work? Am I going to have to wire in a resistor or filter or something else to get it to "ignore" the low voltage blips and wait for the higher voltage of the turn signal light coming on?
Any help would be appreciated.
