again take a brake test
1. always use the same spot and the same speed, 1st time use just the front brake, 2nd time just use the rear brake, and the 3rd time use both brakes.
there will be very little difference between the front brake only and the using of both brakes.
rear brake only does the least amount of good by far, and is easy to lock up the rear wheel if you push hard.
now because this bike has linked brakes only when you use the rear brake it will stop you better but still not as good as the front brake only.
of course if you always want to use both do it.
when conditions are bad and slippery use very little front brake, like on dirt roads I use back only.
if the front locks you are down, if the rear locks you can recover.
