Not in this case. Bead is way to far away from rimStarter fluid?
The trashbag idea has some merit but this tire is stiff. I have a real 120PSI air compressor but right now I am gonna try a tire shop and a Deere dealer.....If you have a real compressor, not a cigar lighter powered portable. Remove the valve stem for max airflow, then loosely stuff a trash bag in the opening and try adding air. If the tire inflates you can trim away the excess bag with a razor blade. The ratchet strap method is the best, if it works. The starting fluid method works well at times too. If worse comes to worse, take it to a tire shop and for a few bucks they will fix you up.
For some reason....the bead is way too far away from the rim and pressing the tire doesnt help......Put a tiedown strap around the perimeter of the tire to force the tire bead closer to the rim.
playback disabled by video owner
Used this method for years putting ATV tires on rims. Also used on some motorcycle tires that had been compressed too long. Works well.Put a tiedown strap around the perimeter of the tire to force the tire bead closer to the rim.
My tires got a bit old and dry however the tread was still good so I put "Slime" tubes in mine 3 years ago and they are still going.For some reason....the bead is way too far away from the rim and pressing the tire doesnt help......
