Honda Top Box: Inside dimensions ? ie will it hold ... ?
ett
Allentown, PA
I'm considering buying the Honda Top Box for my NT.
I want it for one reason; and one reason only.
I want to hold my lunch cooler during my daily commute.
My cooler is one of these:
Ozark Trail 24-Can Cooler with Removable Hardliner
and it's dimensions are:
12.50 x 9.50 x 11.00 IN
I've searched; but was unable to find a thread that mentioned the inside dimensions of the Honda Top Box.
I'd hate to spend a few hundred dollars only to learn it won't meet my needs.
Is there anyone with the Honda Top Box that can confirm; or deny; if it would hold that cooler ?
Thanks;
--ET
Richardson, TX
Thanks;
--ET
I have done the same and I will
Measure my lunchbox when I get home tonight
I use a 24 can Arctic Zone soft cooler in my Honda top box for 5 years now. The cooler came with a 11.5X7x10" hard liner that I don't use because it fits easier . The entire bag measure with the hard liner measures 13x10x10.5 and it will fit in the top box in that configuation, but it is tight. It would fit better if I removed the 1/2" thick pad in the bottom of the top box. I don't use the coolers hard liner and it fits easy even with the pad left in the top box.
Measure your hardliner's height as it will be the limiting factor. If it is <10" the bag will fit. If it is 10.5", then it probably would fit but only if you remover either the top box pad or the cooler's hardliner.
My Shoei helmet just fits with the rubber pad in place. It is approx 10.5" tall. I think anything taller will be a problem
Richardson, TX
I use a Coleman insulated soft lunchbox
10.75" tall
13" end to end
9" front to back
Fits in the Honda topbox no sweat.
Val de Marne, France
2010 NT700 & 2019 FJR1300
Lunchbox has a very different meaning in the UK...
[video]https://youtu.be/pzFHaJ07Fjc[/video]
ett
ett
Allentown, PA
Cool !
Looks like the top box will work for my needs.
Thanks for the measurements everyone !
--ET
