Anyone had success getting a stuck key out of luggage lock for side cases? I have looked on the web n tried all ideas. Is a locksmith my only hope?
Wow.....I sure hope that works. So you could never unlock and pull key out in unlocked position? The salesman mentioned owner said to give right lid a good push n key would come out I tried but maybe the release handles werent fully closed. I did take the seat off n noticed alot of old thick grease n thought that needs cleaning and relube...Make SURE that you have completely latched the lids or the key will not come out. Also make sure that the little handles that you pull to release the lids has returned to the out position or the key will not come out either. I had this problem when I first got my 700 and it was just that the little pull handles needed lubed so that they fully returned. You can just make sure they are returned outward first.
Cliff
Correct. You cannot remove the key in the unlocked position on the bags.Wow.....I sure hope that works. So you could never unlock and pull key out in unlocked position? The salesman mentioned owner said to give right lid a good push n key would come out I tried but maybe the release handles werent fully closed. I did take the seat off n noticed alot of old thick grease n thought that needs cleaning and relube...
Ty
Greg
I got the key out and cleaned all that gunk I could get to and now understand a bit better of how it works. My right case just wouldnt latch where the lever would go back to to closed position. Noticed that they jb welded those metal tabs on the lid. Figured they weren't pushing the latch enough where it would hook on when the spring would latch on to it. So temp hot glued a little piece of wood on the end of the tabs and closed lid and it latched into place... so off comes the temp n a little jb weld to add just a bit on the end of tabs. Think it will work! This NT forum is great n ty for replying with your knowledge Cliffh. Helped out big time!!!!!Correct. You cannot remove the key in the unlocked position on the bags.
Your are very welcome, glad I could help. Yeah, Honda could have done a better job on the bag latches....but they nailed it on the rest of the bike.I got the key out and cleaned all that gunk I could get to and now understand a bit better of how it works. My right case just wouldnt latch where the lever would go back to to closed position. Noticed that they jb welded those metal tabs on the lid. Figured they weren't pushing the latch enough where it would hook on when the spring would latch on to it. So temp hot glued a little piece of wood on the end of the tabs and closed lid and it latched into place... so off comes the temp n a little jb weld to add just a bit on the end of tabs. Think it will work! This NT forum is great n ty for replying with your knowledge Cliffh. Helped out big time!!!!!
Yes sir you guys were right...cleaned out hunk n got it working. Appreciate yallThe accumulated grease is likely the culprit. When you have the seat off clean the mechanisms with a spray on parts cleaner and then lubricate the mechanism lightly with a graphite lock lube. With the graphite lube the liquid "vehicle" evaporates leaving just the graphite residue which doesn't attract the muck that heavier greases do. I posted some other info in an earlier thread of yours.
Thanks again Cliff! On another note mine came with a sw motech luggage plate. I see you have a top case. Do you like it? My wife wants a backrest n i like the way a passenger backrest looks but then i noticed some top cases that have a pad for passenger. Guess it all depends if you want extra storage space. Wonder if I had a backrest could a top case still fit without removing backrest?Your are very welcome, glad I could help. Yeah, Honda could have done a better job on the bag latches....but they nailed it on the rest of the bike.
Cliff
Greg
Mike what are combination latches? Any pics? TyYou're very welcome! BTW, the JB Weld you noticed on the latch hasp bosses was likely done by the PO because the plastic bosses were crumbling apart. I did the same thing to mine when I first noticed the degradation of the plastic as did most everybody else on the forum. The JB Weld fix bought me a few more years of service but entropy being what it is had the final say. I removed the hasps and the mechanisms and replaced them with combination latches.
