12 volt Accessory Socket Not Working
andreyk478
I have a 2011 NT700 with 25k on it. Previous owner installed accessory socket, no idea if it was Honda or aftermarket. Socket was working, then I took some body panels off and while putting everything back together, the it stopped working. The two wires that power it should have a 12 volt difference but they do not. I know the socket and charger itself work because:
  • Visually inspected all fuses and they're in good shape
  • Wired socket directly to the battery and it works
Any ideas on what to check next?
Since it was working before, it must have been something you did ;)
Retrace every step, follow the wiring route for the connector that came off/wire been clipped... you'll have to remove some Tupperware again.
The OEM acc circuit/connection is located behind the LHS upper fairing panel.
