Correct, both my ST1300's were typically in the 42-45 range running 'somewhat aggressive'.That 36 MPG may be low for general use. Note that Honda specs show the ST1300 at 35 MPG. But when the mileage on my ST1300's dipped below 40, it was because there was something wrong. Specifically, in both cases, it was a stuck thermostat, causing the engine to run below an optimal coolant temperature. My mileage was almost always between 42 and 50 MPG.
In any case, I figure the FJR is probably on par with the ST1300. Unfortunately, the tank is a gallon short of the ST capacity.
It isn't on sale until November....Is that bike in anyone's garage that we know, Joseph??
I have over 4k miles on my 2013 and run between 40 and 50 mpg. My best is 52 and my low is 38. The 38 mpg was on I 90 at 80 to 85 mph. This is actual not the computer. However the computer is within 2 or 3%. Keep in mind that I can push this much lower if I would ride harder.Correct, both my ST1300's were typically in the 42-45 range running 'somewhat aggressive'.
Seems like move manufacturers adjust the size of the tank to around a 240 range on a good day.
Actually, acquiring the new, "perfect" bike seems to be like getting married to the "perfect" spouse: "She'd be even more perfect if only she ..."I don't know what I'd do with my spare time if I bought that bike - farkling looks complete already. Maybe put some cards in the spokes or something.
If going from ~60 horsepower to ~140 horsepower is "just a little more horsepower" I'd like to see what you would consider a lot more horsepower.......for just a little more horse power....
I have to agree that it is not a little more horsepower it is a lot. However on my 2013 the drive mode helps control it. When I am just running around or on interstate highway I am in D mode. Nice and smooth with good power. Hit the twisty roads and go into S mode and wow is it fun. Very little wrist movement is needed to add power. As I continue to build my skills, tune the suspension and upgrade to PR3 tires I will have the perfect ride. That is until the next one catches my eye. Oh, and my wife say ok I can trade. I still don't know how to sell the idea of needing more then one.If going from ~60 horsepower to ~140 horsepower is "just a little more horsepower" I'd like to see what you would consider a lot more horsepower....
