When I bought Horse from Joe Forstie (Frostie on the Forum) in 2019, he had farkled it almost exactly like I wanted it. During my ride home from Spokane, I decided that since I had lost about 65 pounds since I had bought my heavy duty Russell Day Long saddle, that I didn't need the "heavy duty" part of that great saddle. And it turned out that Russell had come out with what they call a Sport Seat -- no spring, and the height of a stock saddle after it gets broken in. I got it and it's great.
Frostie didn't ride much at night and he'd put on the smallest Denali driving lights. They just weren't bright enough when it got dark, so I installed a pair of Clearwater Darlas that have 2400 lumens each. They having a dimming feature that is adjustable between 10% - 90% and to to 100% when high beams are on. I'm running them at about 30% with my low beams. I also added LED headlights. They're a good bit brighter and don't pull as many watts as the H7 bulbs.
The McCruise on the bike when I bought had a vacuum-actuated servo. The first cruise control I had on my first '99 Concours was vacuum actuated and worked pretty well, but the higher my altitude or on steeper grades, it couldn't hold a steady speed. I replaced that with an electrically-actuated Audiovox cruise control and it worked much better but still with some limitations.
The vacuum-actuated McCruise would hold between 60-65 for me. Frostie said it had done better for him. We figured out that I probably weighed 70-80 lbs more than he did, plus I had larger windscreen. I noticed that up in Wyoming where the altitude was above 6K feet, it would barely hold 60 if there was any wind or grade.
After Ken and I rode together I observed that it accelerated at a pretty good rate when I asked it to. It held 75 easily and the speed didn't vary more than a mile or two. There is a little tweaking left to be done. When I push the set/accelerate button to resume speed, it just sets the speed I'm at when I press the button. The other negative thing I noticed was that on two occasions when I went down a fairly steep hill, the speed would creep up and when it got to 6-7mph above the set speed, the cruise would disengage. I'm pretty sure I can do some reprogramming and fix those things. Other than that I was very impressed with its ability to hold a steady speed and I think I'm going to be very happy with it.
