Are these only offered in butt splice style? I can see where they would be handy for many people in several farkling situations.
For me though I don't see much advantage over regular solder and heat shrink sleeve.
I agree with Brad (ARKNT) about solder and heat shrink.
Pick up some electrical grade "silver" solder at your preferred hardware store + several different sizes of heat shrink from the same department. Practice a couple of times sticking two pieces of wire together: First slide the shrink tube a distance up one wire,
away from where your heated connection will be. Interweave & twist wire strands of the two wire ends. If they don't pull apart easily, you should be okay. Then apply heat "upstream", one way or the other, from the center of the connection. When the wire is heated by solder gun, or just with a lighter's flame, and
the wire reaches the melt temperature of the solder, touch the solder to the wires. The melted solder will "run" along the strands directly to the heat. Yes, it seeks the heat. When you like the connection, slip the insulator (shrink tube) over the connection and heat it (gently) until it shrinks to a water-tight fit.
Sometimes you can trim a couple of strands from the end of each wire to make a smaller "bulge" at the connection point. Just don't overdo the trim job or you'll increase the resistance to electric current.
You'll get it after a couple of tries. If I can do it, any one can do it.
A bit of solder and a few lengths of shrink tube take up no room in your tool kit. And when you have that skill, you'll be amazed at stuff you can fix.
I must add that I like the Posi-Lock option though. I may get some of those just-in-case I'm in the middle of a road through a low-lying swamp/bog on the ALCAN, being devoured by mosquitoes, and fixing a wire broken by the brutal jarring from an unseen frost heave in the road. Oh yeah, it happened! But why did it have to happen to us?
