Wow, did Honda hide that little white 4 pin connector for the accessory circuit well!
With the help of my lit inspection mirror I found the little guy securely tapped to the wiring harness running along the left side of the upper fairing frame rail. I could only see the very end of the capped off connector.
Fortunately, my hands aren't real big and I was able to unwrap the electrical tape securing the plug to the wiring harness. Also (again fortune smiled on me) I'm relatively familiar with Honda's various connectors. I was able to find the tab at the rear of the connector and depress it with my thumb and squeeze my other hand into the hole and pull the end cap off.
I was then able to plug in the accessory harness, tuck the 4pin connector up into the above connector boot and zip tie (both hands needed again) the accessory harness extension to the wiring harness. I'm now ready to wire in the heated grips.
I did this all with just the left fairing lid cover removed. If you have "average size" hands for a man, this will likely be a tall order without removing the left upper fairing :frown: unless you are real good with using 2 long hemostats blind.
