I purchased a Roadcrafter R-3 that I received last Friday. I have been wearing it for my daily commute and while its to early for a comprehensive review I thought I would provide a few comments.
It doesn't matter how good a piece of gear is if it does not fit well you are not going to use it. I am fortunate that my body is pretty well proportioned for my height and weight so the 38R I ordered fits me perfect. The arms and legs are the correct length and it fits with room to spare over my work clothes and has room for a winter layer when the time comes. I also purchased the optional hip armor which installed very easily. Without a liner all of the armor is easy to get at to adjust, remove or install.
I love all the pockets. It has more than any of my other riding jackets and pants and they all seem to be in the right place and are the right size as well.
Venting. The R-3 does not have a lining in it so the zippers under the arms and in the back open directly to your body and you can clearly feel the airflow. I am afraid however when it gets above 90? and with my airbag vest over it that I will most likely switch back to one of my mesh jackets. The R-3 should be good for anything under 90 however.
It raining out now so I should get a test of how it does in the rain on my way home tonight. One of the reasons I purchased the R-3 is for the built in Gore-Tex which should eliminate having to put on rain gear which can be a real hassle.
Putting it on: I watched the video and putting it on is very easy with the exception of starting the main zipper. As most of you know the suit zips from the top down. Bringing the zipper into the zipper pull from the bottom is awkward and being that its up around my chin I can not see it very well. Its like trying to thread a needle in the dark. It is getting easier with practice.
It is clearly a quality piece of gear with a lot of thought put into it. I can see why those that have them speak so highly of them.
As I use it more I will update this post.
