I didn't look at the video before, but I just did. If the oil pan and rockers are clear, which it appears they are, that engine has some serious problems. What you are seeing is an emulsion, not pure engine oil. He says that air is being whipped into the oil casuing it to foam... that's not foam. Somehow or another I suspect that engine coolant is mixing with the oil causing the emulsion.
I'd to agree, likely symptom will be "peanut-butter" at the underside of the "710 cap"...
Seriously, my ST1100's block has a view-glass, never saw such a coloring and it would alarm me TOTALLY...
; new oil nearly transparent (dyed by MFGs specs, green, blue, yellow, red...) and starts to darken with usage (carbon deposits, micro shavings, etc...)...
Cold starts are hard on any engine as clearances are designed/fabricated for full operating temp, hence a cold engine will seep and suffer wear on parts...
24 hour radio cabs/taxis run endless miles cause their engines never cool off, whilst your sedan used for commuting will see at least two cold starts each workingday ...
In winter some riders developed the (bad) habit of starting the engine and letting it idle for a few minutes every week or so...
bad idea!
Besides excessive wear due lack of lubrication each (cold) start blows gases, partially unburden fuel and condensate by the rings... water and exhaust gases make a highly corrosive mix, breaking down the oil...
