slowtrot
I was out playing in the gravel the other day and did a 40 mph get off. First time in years of careful riding. No broken or bent mechanicals. Some broken plastic parts but no broken me. Not a scratch or even roughed up GOCs (get off clothes). I really like the NT700va bike but aggressive gravel riding and a faired road bike are probably not a good idea. But I did not buy it to give it a home. At any rate I got to take the bags off and look at the latch devices. Now I know why they dont work so good. They are complicated little buggers with cable activators. They are unpolished stamped metal and at the factory they were coated with gobs of heavy grease. Road grunge will then accumulate on that grease and stick. The grit will make the triggers bind and not function. If you have that problem, take off the bags, remove the assembly and wash the the grit off with a solvent and use some oil rather than grease. I have done a little polishing on mine and now they are behaving themselves.
