Phil, I have my battery tender, voltage monitor, and Fuzeblock connected to the battery terminals. All these connectors effectively shorten the bolt. What I experienced was the terminal bolt would not thread into the nut under the terminal. I cut a small piece of foam and jammed it under the nut to keep it pushed up against the top of the terminal. The bolt threaded right in.
If I add any more connections to the battery terminals, I will have to buy a slightly longer bolt. Which I had to do on the Wee, cause I have four connectors to each battery terminal. IIRC the battery bolt is a M6?. The length I bought was 12mm.
Any way it has to be slightly longer than OEM. I found replacement bolts at Lowes.
