Yesterday I went over it to see what's what, and cleaned it up. I wanted to check the oil but this turned out to be easier said than done. It has a sight glass, which is blocked by the sidecar. I could only see the bottom half of it. Either there's oil in it or the glass is oil-colored. I could not see the top of the oil, and it was too dark to see with a mirror. I will have to tackle this project again with a mirror, a different flashlight, and perhaps a second pair of hands to hold the flashlight.
I checked the tires. It has a new rear tire that looks good, but was at only 25psi. The bike's sticker says it should be 42, so I added some. I didn't find any damage, so I don't think it's leaking. Still, best keep an eye on it. The sidecar tire was at 25 as well, and I couldn't find anything saying what it should be filled to, so I left it alone until I read more of this paperwork. The front tire was at almost 30, and should be at 32, so I added a little. The front tire is not down to the wear bars but it is obviously worn and there's a little bit of cracking action starting in the tread recesses, so I will probably get a new front for it soon.
The rear brake, which is almost completely non-functional? I think it may be adjusted badly, but I couldn't figure out how to change it, so I will have to read manuals and look again later.
I got the Givi plate off, and removed the side bags. I'll hold onto the side bags just in case, but I have sold the Givi topcase to a local friend, because I already own several Givis and don't need another. I can't really see a need for any cases on this bike since it has a huge trunk.
And speaking of trunks, I went through the trunk to see what all the mysterious bundles in there were. There are two motorcycle covers. I didn't unfold them. Perhaps one is for the bike and one for the sidecar? There is a black and purple rainsuit that stuffs into a built-in pouch and turns into a fanny pack. Size medium, and if it has ever been used it wasn't a dirty day. I wonder if it belonged to whoever had the bike lowered and put this deeply dished seat on it? There is a nylon duffle bag that proved to be full of BMW parts - some used, some perhaps new and have just bounced in the trunk for years. A pair of front brake pads with lots of life left in them. Rear brake shoes that look new. A bundle wrapped well in newspaper and packing tape, labeled "clutch" which I didn't unwrap, but it does indeed feel like a stack of clutch plates - no idea if it is new or used. A wheel bearing in a box labeled "used". Some obviously used radiator hoses.
The front and rear suspension both have aftermarket shocks, labeled "Progressive Suspension". A reputable brand.
I did not dig into the wiring, though I need to do that. It has obviously had some mods, and I have no idea if they were done properly or not.
I didn't detail it but I cleaned it better than it had been cleaned in a while, I think. I still have a couple of cans of S100 engine brightener from when I used to polish the Sabres. Newer bike engines don't have that black coating that was popular in the 80s, which responded so well to S100, so these cans have sat on a shelf for years. The BMW has that kind of engine finish, so I sprayed it. Looks nice. I waxed some of the painted bits, but got bored before I finished. Does wax really truly do anything, or is it just an illusion caused by the fact that it goes on hazy and the shine comes back when you wipe it off?
