Trying to figure out how to change out the turn signal indicated lamps on the dash. Anyone know how to get into the dash? Thanks
You might want to check with a Honda dealer. I am not 100% sure but I think that all instrument lamps are LED's and are part of the assembly. I took mine apart because I wanted different color gauge lumination. Did not see any replaceable bulbs. Everything was soldered in. Check for a loose connection. If you need to replace the unit it is about $358.Trying to figure out how to change out the turn signal indicated lamps on the dash. Anyone know how to get into the dash? Thanks
