Cigarette lighter
lcseds
I was at the dealer today looking over the silver NT. So where does the cigarette lighter plug mount? I did not see a spot in the left or right pocket. My wife's Silverwing has an obvious cutout and plug space in the left pocket. Don't see it on the NT.
I just drilled a hole. I put my power outlet in the right fairing pocket, but I also drilled a hole on the left for the mini-din plug for my audio. Neither pocket had any marked holes, but there's plenty of room. Note that you do have to put the plugs in the bottom half of the pocket, so there will be room for the socket in the hollow space in front of the pocket. When you take it apart you will see what I mean.
lcseds
Okay thanks. I guess it's "drill it where you want it". Good for me, just was not sure I was missing it's intended located from Honda (with consideration to harness lengths). I saw in the showroom access was limited unless the handlebar was moved.
