Mgoekerjdjs
I have chance to buy 2010 Honda NT all luggage including top back. Is that detatchable? 33k miles I know guy took care of it. Is $2500 good price?
Um... the stock Honda top case CAN be unlatched with little effort. Just use the key to open the latch, pull the red knob, and it lifts right off.Compare the price to what you might see on Craigslist and CycleTrader. 33K miles is not a lot for this bike. As Phil said, the top trunk is detachable, but only by removing a lot of screws and bolts, it can't just be unlatched for example.
I never knew that! Thanks!Um... the stock Honda top case CAN be unlatched with little effort. Just use the key to open the latch, pull the red knob, and it lifts right off.
If you have aftermarket brake lights installed under the lenses in your top case, be sure to disconnect the small electrical cable before snatching your top case off and heading inside with it!I never knew that! Thanks!
thought the Honda top box was like my Givi: unlock it, push a button. and lift it of
I thought the Honda top box was like my Givi: unlock it, push a button. and lift it off.
It sounds like a good deal. I would still look a little close myself. Be sure to check everything out closely and make sure the bodywork is all there and in good condition. See if the seller will let you take it for a test ride. After the test ride, that should be enough for you to make a decision. $2,500 is a great deal if all is on the up and up.I have chance to buy 2010 Honda NT all luggage including top back. Is that detatchable? 33k miles I know guy took care of it. Is $2500 good price?
I am with CR. The market place is wild. GM is shutting down North America production due to chip shortage....that is not cheep to do. Look at the cars/ bikes that were ruined in 13 states due to fires and floods.....and they have chips too.I wouldn't sell either one of my NT's for $2500!
I just bought a 2010 for $4k. KBB had it at $4500 fire this area, St Louis. Mine had 8100 miles.I have chance to buy 2010 Honda NT all luggage including top back. Is that detatchable? 33k miles I know guy took care of it. Is $2500 good price?
