The bike will certainly be full of non-ethanol fuel and properly stabilized for sure. And the battery tended.
I see my choices as three . One,Of course, is you run up the bike (and oil temp) once a week or so, riding or not depending on
conditions (I live in a hilly, shady black ice zone). The pistons stop at different points each time you stop the bike, of course. Indeed,
when the ignition switch kills the fuel and spark, the engine dies still oiling the cylinder walls, and while the oil scrapper ring still works
to some extent, at least parts of both cylinders will be protected for awhile. Nothing wrong with that. If you drive your car once a week, the same thing happens. No worries.
Two, If one just parks the bike in a cold garage for five months, I do not personally believe any bike is a "closed system". As the air pressure rises and falls, cold damp air will come and go through
the valves that are open, either intake or exhaust, and also probably by the rings after awhile. I do not know the composition of the cylinder liner but probably any surface rust would be very minimul,if at all, even in cold damp foggy spokane
(Home of the ice fog).
I do know I have had to chip out a piston out of a cylinder with a hammer and a chisel on a bike once due to , and I am guessing, disimular metal corrosion over many years of no use (I was given the bike).
But,I think the bike would fire up right away in the Spring.
And three, I can inspect those bogus spark plug caps that dont look like the two new ones I bought and fog the cylinders. Or at least one. I have about a month to decide!
