If I am going to store the bike for two months or more, I always store the bike with fresh oil and filter. It does not have to be anything fancy--you can get a Wal-Mart filter and some run of the mill 10W40 Oil for the storage period. You said that you put 1700 miles on the oil before storage. If it is expensive synthetic oil, you can always save it for the spring. Warm the bike up, drain the cheap oiil, change the filter, and put in the good stuff you drained--add the deficit, and you are home free.
I use Honda Synthetic and change at 5000 mile intervals. I don't have 5000 miles on the bike. I'll drain the oil and change the filter and use the drained oil in my snow blower, or lawn mower. That's what I did with the Ninja. My lawn mower was very happy with Rotella T-6. I just put it in storage with a fresh batch of T-6.
Oil, after some use develops acids which wreak havoc with bearings--so if you are not going to use the bike, it is best to put in fresh oil and not start the bike while in storage. My bike sits in a garage/shop which never gets below 55F. It also gets ridden when the roads are dry and free of ice. If it looks like a long winter in which I can't ride, I winterize--change the oil and filter, lube the cables, give the bike a wax job, check the coolant, put a block under the bike so that the front tyre is off the floor, plug in the Battery Tender, cover the bike, and wait for spring.
