Went to start bike today and it turned over very very slowly, made a few clicking noises and shut down. Turned key off and back on, nothing happens - no displays at all, completely dead. Thought my battery was bad, but charger said it was 90%. All fuses near battery are good, 30 amp main fuse on side of the battery is good. + and - terminals are clean and tight. Measured battery while turning on key and it fluctuates and settles at less than 1 volt. It appears as if something is sucking all the juice and I didn't leave the key on long assuming something might overheat. Could starter/relay be jammed and causing this problem? I was able to put bike in 5th gear and rock it until it turned over a little - didn't help. Anybody have other ideas?
