Background - I've had the engine not start previously and got the engine code 19. The bike would turn over, but never start - like there was no spark. After waiting 20-30 minutes the bike would start right up.
Commuted to and from work on Tuesday without issue, in the 30-40 degree temps. Stopped at the house for 15 minutes and then rode 10 minutes to a friends to drop something off. No issue. Drove about 5 minutes from there to visit another friend in the hospital. No problem. After a 20-30 minute visit, the bike will turn over, but not start - engine code 19. Opened the half-full gas tank to ensure it wasn't a vacuum, but no change. Crank, but would not run. Went back inside for 20 minutes or so and when I returned it started right up. No issues on the ride home.
Yesterday morning it was in the upper 20s and when I took the bike out - after being on the Battery Tender overnight, it wouldn't start immediately - cranked plenty fast but no "spark". Then when it did run, it felt like it wasn't hitting on all the cylinders. I increased rpm to 7K or so to see if it was something sticking, and it seemed to idle okay. Hooked up my electric gear and took it to the top of my driveway, where it promptly conked out. Drifted it back to the garage and got out my PC800 - old reliable - which promptly wouldn't start. Even hooked up to the car battery, all it did was turn over, regardless of choke or throttle. So I put the PC800 back and tried the NT again and it started without issue. Drive to work was without incident.
Starting for home after work, it ran rough again so I had to manually keep the rpms up for 5 minutes or so. At that point it idled fine and I had no further issue. So this points to a potentially "cold" issue. Thought it might be the gas, but it was fine for the first half-tank. Fuel filter would be more of an issue on acceleration, I would think, rather than idling, but with the computer, it could be trying to do something based on bad input, so I'm at a loss.
I know I've provided a lot of info, but I didn't want to miss anything significant. Oh, it's not time for an oil or filter change but the antifreeze is just over 2 years. Can't think of anything else. Hoping someone else has diagnosed this problem so I can stop this crap once and for all.
Cameron
Cameron
