Fisherdave
Let me apologize in advance if this topic has been covered & I missed it.
I have encountered a problem with my bike stalling at low RPM. This is particularly evident when I shut down the throttle & then open it again. It usually occurs when I'm coming up to a stop sign & am shifting down. Sometimes the bike will stall out completely when I pull in the clutch to stop. Other times it will stall when I am taking off from a stop sign. It is also evident at around 3K RPM in either 4th or 5th gear. It tends to want to stall out. I have to pull in the clutch & give it some revs.
I have taken the bike to the dealer & have had the spark plug ends replaced as indicated in the service bulletin. That did not help.
At one point I had a dash light come on that indicated a fuel injection issue. The dealer did a diagnostic & then replaced the MAP sensor (under the emissions warranty 5 years 18K miles).
I got the bike back last week & the problem continues. An interesting side note, however, is that when I add some gas additive (STP Fuel Dry) it seems to run just fine. I did this originally because I thought I may have gotten some bad gas. Although this is a possibility, I have my doubts that I could have gotten 6 tanks of bad gas.
The bike is a 2010 w/about 14K miles on it.
Any thoughts, theories, wisdom, etc. will be greatly appreciated.
