MaxBC
After reading about the spark plug cap issue, I thought that I would swap mine out while the bike was in winter storage. I pulled the necessary tupperware, and standing on the left hand side of the bike, propped the front of the fuel tank on a chunk of 2x4. I changed the left cap. When I went to the right side (front cylinder) I found the pictured block of foam resting inside the bodywork near the radiator reservoir. The self-adhesive side had evidently given up in the garage's cold.
It's a fairly dense foam block measuring .5" x .5" x 7" with one tacky length. It's not perfectly straight. It doesn't show any real signs of compression. Looks like it might fit somewhere between the tank and the air cleaner housing cover.
Pictures attached. Where exactly does this go?
Thanks,
Max
Thanks,
Max
