Sprung a leak.
I have noticed a strong smell of gas in my cold storage machine shed for the last couple days. I checked the snowmobile which I recently refueled. I checked the car which had a leaky fuel filter recently. I checked the truck which I just did some brake line replacement on. No leaks found.
Today I found the leak. There is a LARGE puddle of gas under my NT which hasn't moved in over two months. It is stuck in a corner, blocked in by other items, and covered. So I can't access it much less look for the leak without lots of effort. Before I stored it for the winter I adjusted the valves and changed oil. I didn't disconnect the fuel system in the process, but tilted the tank up and worked around everything. Afterward I went for a test ride and filled the tank with gas and stabilizer. All was well. So then I removed the battery, put it in storage and covered it.
So, today, when we are under wind chill warnings, I'm spending my time thinking about part could be leaking, and how I might deal with it. I doubt if a rodent chewed anything because I stored it with bags of moth balls in strategic places, I have never replaced the plastic quick disconnects as per Honda manual, and I don't want to move a motorcycle that is leaking gas into my heated shop. First clue is that it started abruptly when the weather got very cold. Another clue clue is that my wife has a dead mouse in the heater/deforster of her car.
Any ideas? I plan to attack it in a few days if it warms up a little.
