Gauges Not Working
jp-nj
About to take my NT out for a ride and noticed that the fuel gauge, tach & speedo are not working. Was working fine when I last put the bike in the garage. All fuses check out fine. I have been checking connections from the gauges to re-seat, no luck.
Anyone else have the same thing happen to them?
Thanks,
JP-NJ
Northern Virginia
Several other NT'ers have reported gauge cluster failures, but the only poster who responded that he had fixed the problem ended up replacing the cluster. Check the electrical forum for a thread "my gauges don't work" There are a couple of other gauge threads, some suggest the problem might bring related to corrosion, but no one has actually reported finding a bad connection. Hope you can fix the problem without needing a replacement. Please let us know what you find.
silshooter
Crowley, Texas
The mileage function has not worked since new.... Occasionally the instruments will not work, but a shut down and restart will correct the issue. This appears to be a humidity related issue.
LP-NJ
Did you find the problem? Hopefully it was simple and not costly.
Thanks,
JP-NJ
Does the headlight work? ...turn signals on the dash and at the indicators? ....horn? Does the self check on the dash do anything when the ignition is turned on?
