There have been reports over on the FJR forum that the drive splines and U-joint does not have enough lube on them from the factory. So today I decided to get intimate with Ruby and find out. Pulled the rear wheel. (About the same as the ST) Pulled the cover to access the U-Joint. ( Much easier than the ST. Do not need to pull swing arm.) And pulled the rear drive. About the same as the ST) U-Joint just comes out and is very easy to lube as necessary. Took about 30 min to get to that point. Will lube up all the parts with Honda Molly and then hope I remember how it all goes back together. Seems to be real easy Job. The pictures show the factory lube with 1600 miles on the bike.
Attached Thumbnails Attache
