Gina's BMW in Iowa City has taken over new ownership and will also deal with Triumph motorcycles...Gina and Julius are retiring...wish them much happiness
Uh oh - I did the same thing in Houston recently. That could be dangerous .. . . . I kicked the tires on a R1200RT . . . .
Just exactly which "thing" did you do?Uh oh - I did the same thing in Houston recently. That could be dangerous .
(I do NOT need a new bike. I do NOT need a new bike. I do NOT need a new bike.)
Both !!Just exactly which "thing" did you do?
Wander into a motorcycle shop on a whim or forget what state you were in?
I think one is more dangerous than the other, but I'm not sure which.
George, you've probably told us before, but what was the problem you figured out?Bob's BMW finally fixed it after I figured out the problem and proved it.
Fuel pump failure when hot.George, you've probably told us before, but what was the problem you figured out?
Yes. The early bikes also had idle air hoses which could become kinked and cause stalling. They were replaced with pre-formed hoses that eliminated the problem (another example of BMW using their customers as beta testers). There was a tendency to blame fuel pump controllers on the F800s because of controller failures on the GS models, a known problem. However, on the GS models, the controller was exposed and subject to corrosion, but that was not the case with the F800 and there were few actual failures although a lot of controllers were replaced on suspicion. Another cause of stalling is that the bikes are tuned very lean at idle to meet emissions standards. That problem can be improved by fooling the intake air temperature sensor to think that the temperature is colder than actual which causes the controller to richen the mixture.Did a new fuel pump eliminate the problem?
