maxweljames
I was told by a coworker that followed me to work the other day that my brake lights on the top box were flickering all at the same time. After some experimenting in the garage I found that there is enough movement between the mount and box to cause a disconnect.
So tonight I need to see if I can fix this problem by shimming the mount connector up to provide a better contact surface with the box's spring loaded terminals. Worst case is I have to install some kind of hard connection.
Has anybody experienced this before and what did you do to fix it?
