used to be in Tumwater,WA, but I think they moved to Stoneville,NC
Are you saying that the right glove has no (0)resistance. If so it should be getting very hot. Or did you mean that it has infinite (max)resistance meaning the wire is open?Mike, good point. I should've thought of it myself. My ohmmeter was one of the first tools my Dad gave me, and one I find extremely useful. The left glove has about 12 ohms of resistance. The right glove has 0 ohms.
I suspect the gloves will have to be returned. The question is if it is North Carolina or Olympia. If Olympia, it might be worth a ride down. Let's see...Thursday is clear, the temp is supposed to hit 37F for a high and only get down to 31F... I could use it as an excuse to get a picture of some cities with "O" and "T" and a few others in between.
Chris
Yup, sounds like the right glove has an open circuit, thus no heat. You said that the left glove just barely gets warm with the controller on high... it "should" be putting out pretty good heat with that resistance reading. I dunno about the Gerbing's, but the Tourmasters have a temp sensor in the circuit that will not allow the gloves to get too warm. It could be that you are trying the glove in a warm location and a similar circuit on the Gerbing's is preventing full heat..... or, the gloves could be wired in a series arrangement and when one glove goes it takes the other one with it.... kinda like the old Christmas lights.
Hope this helps!
I feel your pain, I have been spoiled by heated gloves and can't imagine riding in temps below 35 or 40 without 'em.
A short would be less resistance, more current flow, more heat until the wire burns open, then max resistance ie infinity ohms. no heat. I have a left glove that is giving me no heat and I measured it. Infinite ohms.Chuck, I interpret the reading of 0 ohms as being a short. It should read around 12 ohms like the other glove, which does work.
Chris
Now that makes since to this old retired bio med electronics tec. Glad you got it figured out. Hope you can get Gerbing to replace your gloves soon. My Warm & Safe gloves are 5 years old and not under any warranty any more. Working on getting my grown son and Daughter to get me the New Gerbing EX heated gloves for Christmas. Hope I can get by until then.Chuck, what you wrote got me to thinking. I suspect I had the leads touching, which is why it read "0". I checked them again and it is open, or infinity ohms. I was able to wiggle the leads around, trying to see if there was something loose. No difference. There's just no continuity in that circuit.
Chris
Before "you up the fuse" to a larger size make sure the existing wiring can handle the load. Over fusing is a good way to create nasty electrical problems, all the way up to a fire, if the wiring isn't the proper gauge to handle the additional load.This is unrelated, but I would up the fuse to a 12 or 15 amp. I think the jacket requires 9, and the gloves are 2? Ah heck I forget. Maybe the 10 on there is fine.
