And you vacuum mold it by putting it in a bag of some sort, and sucking the air out with your shop vac? I'm very interested in this process because I can think of other things to make, as well.
Well, that's a different process that I don't think would work with a heated part. I use a vacuum bag for veneering, but it uses a vacuum pump.
What I did was make an airtight box with a hole in it to accept the shop vac hose. The form is placed on the box and the perimeter marked, then a series of ?⁄₈" holes are drilled just outside the mark. A 2" frame the same size as the vacuum box is made and the plastic stapled to one side of it. The frame is stuck in the oven plastic side up and heated until the plastic becomes...um...plastic...
. When it's ready, the vac is started and the frame is flipped over and pressed over the form until it seals against the box. The vac sucks the air out from under the plastic through the holes and molds it to the form. That's the quick and dirty.
