I searched for this topic because this evening I noticed an odd behavior in my OEM heated grips. A couple times it was mentioned here that the Honda controller has a low voltage function indicator. I'm wondering if what I observed is this low voltage function. After I start the engine, unless I wait at least about 10 seconds before pressing the power button on the controller, pressing it will cause all of the LEDs to flash 3 or 4 times per second for about 5 Seconds. Then the grips will turn on, and the heat can be reduced. the grips are heating up fine. This is very repeatable. Is this the low voltage indicator that is spoken about? If so, it is odd because I actually have a dedicated voltmeter on my dashboard, and voltage at the battery is just dandy. So if it's a low voltage problem it's not the battery. Where else would I look for a voltage problem if this odd flashing behavior of the controller is indeed the low voltage indicator spoken of here? I should also mention that after I start the engine, if I wait 10 seconds or more to attempt to turn on the grips, the controller functions normally, with no flashing LEDs.
