Any thoughts on a possible current draw? In the process of installing a plug for heated gear last week, I disconnected the battery (negative lead first, positive last.) Then, when reconnecting the battery, after first connecting the positive lead, as I touched the negative lead to the battery terminal, I saw a very light spark. Got my multitester and I measured a draw over (I think) 250 ma between the negative battery post and the negative cable lead, but before I could reset the tester and figure out the dial readings, the draw stopped. No spark, no reading. Key was out of switch all this time so ignition was off. I am confident the problem was not with the heated gear plug, in part because the issue seemed to clear up on its own.
I hate to bring this up but this might be related to my long-running occasional "8 flash MIL" issue. I continue to experience the occasional 8 flash MIL when first starting, and maybe once every few thousand miles, on the road with a bit of a running hiccup. New battery last year and a new regulator/rectifier last month has made no difference. I have gotten used to basically ignoring the MIL, or shutting down and restarting to turn the MIL off.
Now I wonder if I have an occasional current draw gremlin that is causing the voltage to drop, triggering the MIL.
I have never had a flat battery. There also does not appear to be any correlation between the MIL and hitting bumps that might affect a shorted wire or a loose connection.
The Honda book only mentions the regulator/rectifier and the ignition switch as possible culprits for a "current leak." But I think a number of electrical/electronic components get power when the key is off.
My current plan is to continue to live with this issue and try to figure out some correlation with various conditions to narrow my search.
