I've sent the hardware.
Here's the deal with putting a home-made rack on the back of the NT...
There are four mount points. They are all in one plane. The rear two are visible on the stock NT - there's that near-level black plastic panel behind the seat, and it has two screw heads visible, those are mount points. The other two are farther forward and are hidden, you have to take off that piece of black plastic and drill holes to use them. The spots to drill the holes are marked on the underside of the plastic.
The grab rails are painted a color that looks like anodized aluminum, but they are actually stout plastic. They extend back into the tail of the bike, and the four rack mount points are supported by them.
I drew a picture. Bear with me, I don't have a fancy CAD package or anything - I drew it in Windows Paint. But here it is:
All four mounts are essentially like this. The red line is where the bolt goes. The blue is the plastic grab rail and the light blue is the tubular sleeve I just mailed to you. The red line is the path of the screw. The rack isn't pictured but it sits on top. So there's a tube shaped spacer, that sits on a washer. The washer sits on the plastic grab rail and on the metal sleeve which lines the hole in the grab rail. The bolt threads into a funny rectangular nut that fits into a slot in the bottom of the grab rail.
The two rear mount points already have the funny rectangular nut, and a washer/sleeve that fits into the hole in the grab rail. So you just need the tubular spacer of appropriate height, and a longer bolt.
The two mount points that are not already exposed, don't have any of the metal pieces. Just the hole in the grab rail, and the slot under it where the funny rectangular nut sits.
The funny rectangular nuts, I couldn't find any generic equivalents at Fastenal or McMaster-Carr, let alone my local hardware. But they can be ordered from Honda - the stock bike contains two, in the rear holes, and you just need to get two more. The metal sleeves, I mailed to you today. You will need to source the larger tubular spacers, in whatever length you decide you need, to set your rack level. And you'll need to source the washers and the bolts in the correct length. The bolts are M8 size.
Does this help?
