I'm about to install some Denali DM1s. I have located the accessory plug under the left side dash area. I'd like to use this to run the DM1s.
Does anyone know what else is fed off this circut????? I don't want to overload it. I'd like to use the switched wire to run the relay and the hot wire to run the lights via the relay. They draw only about 5 watts each (2) plus maybe a little for the lighted switch. So the current draw is pretty low.
At the same time I'm also re-locating my SAE plug that I use for my electric vest which is about 45 watts. I plan to put this on a 20 amp fused wire off the battery so I can also run my air pump off that if necessary or use it to charge the battery without opening up the bike. I'm not worried about killing the battery with my unswitched vest because I always remember to unplug it after I dismount and come to the end of the cord.
Any suggestions?
I'm mounting the lights off the mirror stem bolts by adding a 15mm spacer under the bolt and putting the "U" bracket on top of that. So I'm using a 40mm bolt to replace the 25mm mirror bolt. It is a neat, clean, and simple install, I just hope it doesn't cause some mirror vibration. I'll try to get pictures up when I'm done.
Any suggestions?
