The rear tire for the Kawasaki EX500 arrived on Friday. UPS delivered it about 4:00. I started changing the tire soon after that. FYI, even with a chain and drum break the rear tire removal was a breeze compared to the NT. The new tire went on without any problems.
The front tire arrived on Monday. I started the install after dinner on Monday night. The removal of the tire and wheel was easy enough, the removal of the tire from the wheel had the expected struggles. When I installed the new front tire on the wheel it went on easy enough. When I aired it up, I didn't get the expected POP when the bead seats. I increased the pressure 20lbs above the recommended pressure. Still no POP. I check the bead visually and it look seated. I felt around the rim and it felt seated, so I installed it on the bike.
After the install, I took it out for a test ride. Down the block, around the block, max speed about 35mph. Everything seemed fine. I decided to ride to the gas station to get some gas. On the way, I felt a vibration. I was thinking I could pull the wheel and tire and get it balanced. Before I got to the gas station the vibration got worse. I started to worry. I turned around and headed for home. About 2 miles from home at 35mph the front tire broke loose from the bead. Holy Crap!! I almost lost it right then and there. I applied the breaks to slow. The handle bars did not cooperate at all. Wanted to turn left and right. Took all my strength to go straight. Learned right away not to use the front break. Don't use the rear break to hard either, the weight shift to the front making a bad situation worse. I finally got it stopped and to the side of the road. Called my wife to come and get me, and bring the portable air compressor. After much struggle, I could not seat the bead with the little air compressor. So I rode/walked the bike back to the house with a flat not seated front tire. Once I was home, I aired up the front tire with a larger air compressor, had to put close to 70lbs in it before the POP seating the bead.
Rode the bike today and everything was fine. I was a little nervous, but good. About 4 blocks from the house ? I ran out of gas. Switched to res and make it to the gas station. The bike ran kinda of bad after the fill up, but is fine this afternoon. Carburetors bowls empty??
This makes you understand the importance of good tires. Would not want to experience that again at any speed.
