Mike,
The front turn signals are definitely single filament bulbs. On my NT there is
not a Turn Signal Based "Running Light" feature from Honda, the Turn Signals are not lit at all unless the Turn Signal is blinking. I'll need to find my original flasher to confirm that.... I do have the "Position Light" in the Headlight assembly lit if you want to call it a "Running Light...
Hmmmmm? If my remembery is correct, Scoot's turn signal lights are on whenever the ignition is on and flash brighter when the turn signal is activated. I will check this out later today and report back. P'raps Honda made a running production change and didn't bother to upgrade the schematic.
